Aller au contenu principal
Royal Kludge GK64 Keyboard Switch Spring Replacement
Ce dont vous avez besoin
  1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: étape 1, image 1 de 2 Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: étape 1, image 2 de 2
    • Use a keycap remover to pull your keycap up and off of the keyboard.
    • Remove any keycaps surrounding the one you are working on if you need more space.
  2. Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 2, image 1 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 2, image 2 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 2, image 3 de 3
    • Use the switch puller to pull the desired switch out of your keyboard.
  3. Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 3, image 1 de 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 3, image 2 de 2
    • Place your switch onto your switch opener, and gently push down.
    • Make sure the switch is securely in place and continue to remove the top housing.
  4. Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 4, image 1 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 4, image 2 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 4, image 3 de 3
    • Use the stem holder to remove the stem, which will reveal the switch spring.
    • Remove the switch spring.
  5. Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 5, image 1 de 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 5, image 2 de 2
    • Align your new spring with the center of the bottom housing and gently place the switch spring.
  6. Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 6, image 1 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 6, image 2 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 6, image 3 de 3
    • To put the stem back, align the stem legs with the metal plate on the switch.
    • Remove the switch from the switch opener.
    • Gently push down onto the housing until you hear a click and both pieces are into place.
  7. Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 7, image 1 de 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 7, image 2 de 2
    • Align the pins located at the bottom of the switch to the corresponding pin holes in the keyboard.
    • Gently push the switch back into the keyboard.
  8. Royal Kludge GK64 Keyboard Switch Spring Replacement: étape 8, image 1 de 1
    • Place the keycap back onto the switch and push down to secure the keycap.
Diksha Sakre
Membre depuis le 09/19/22
228 Réputation
1 tutoriel rédigé
Équipe
York University, Team A-7, Morris Fall 2022 Membre de l'équipe York University, Team A-7, Morris Fall 2022
YORK-MORRIS-F22SAG7
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 12
Total : 356
