Aller au contenu principal
Rubber Watch Battery Replacement
Ce dont vous avez besoin
  1. Rubber Watch Battery Replacement, Battery: étape 1, image 1 de 2 Rubber Watch Battery Replacement, Battery: étape 1, image 2 de 2
    • Begin by placing the watch on its backside.
  2. Rubber Watch Battery Replacement: étape 2, image 1 de 3 Rubber Watch Battery Replacement: étape 2, image 2 de 3 Rubber Watch Battery Replacement: étape 2, image 3 de 3
    • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
    • Pull out the white cap and green chip once it is free.
  3. Rubber Watch Battery Replacement: étape 3, image 1 de 1
    • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
    • Be careful not to insert the X-Acto knife too downward into the battery.
  4. Rubber Watch Battery Replacement: étape 4, image 1 de 3 Rubber Watch Battery Replacement: étape 4, image 2 de 3 Rubber Watch Battery Replacement: étape 4, image 3 de 3
    • Flip the chip around to the front.
    • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
    • Make sure to hold the knife away from the hands in a safe, stable grip.
    • Remove the cut plastic casing over the battery.
    • The plastic casing should come off like a cap.
  5. Rubber Watch Battery Replacement: étape 5, image 1 de 1
    • Gently remove the battery with a spudger or a wooden coffee stick.
    • Using too much force may detach the tab holding the battery and break the watch.
    • Once free, remove the dead battery.
  6. Rubber Watch Battery Replacement: étape 6, image 1 de 1
    • Insert the new battery.
    • Place the cut plastic cap casing over the chip and battery.
  7. Rubber Watch Battery Replacement: étape 7, image 1 de 3 Rubber Watch Battery Replacement: étape 7, image 2 de 3 Rubber Watch Battery Replacement: étape 7, image 3 de 3
    • Place the white cap over the green chip.
    • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
    • Turn over the watch and check the power.
Ligne d'arrivée
Lee
Membre depuis le 04/28/17
110 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S2-G5, Cole Spring 2017 Membre de l'équipe UC Davis, Team S2-G5, Cole Spring 2017
UCD-COLE-S17S2G5
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 787
