Aller au contenu principal
Ryobi P235 Magnetic Tray Replacement
Ce dont vous avez besoin
  1. Ryobi P235 Magnetic Tray Replacement, Battery: étape 1, image 1 de 2 Ryobi P235 Magnetic Tray Replacement, Battery: étape 1, image 2 de 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Magnetic Tray Replacement: étape 2, image 1 de 2 Ryobi P235 Magnetic Tray Replacement: étape 2, image 2 de 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: étape 3, image 1 de 2 Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: étape 3, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Magnetic Tray Replacement: étape 4, image 1 de 2 Ryobi P235 Magnetic Tray Replacement: étape 4, image 2 de 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Magnetic Tray Replacement: étape 5, image 1 de 2 Ryobi P235 Magnetic Tray Replacement: étape 5, image 2 de 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Magnetic Tray Replacement: étape 6, image 1 de 1
    • Remove the magnetic tray from the device.
Paul Sousa
Membre depuis le 10/29/19
805 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 Membre de l'équipe UMass Dartmouth, Team S4-G2, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G2
3 membres
6 tutoriels rédigés
Un commentaire
Thanks for sharing, I was actually looking for these steps.
Mark Robert - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 297
