Aller au contenu principal
Ryobi P235 Trigger Replacement
Ce dont vous avez besoin
  1. Ryobi P235 Trigger Replacement, Battery: étape 1, image 1 de 2 Ryobi P235 Trigger Replacement, Battery: étape 1, image 2 de 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Trigger Replacement: étape 2, image 1 de 2 Ryobi P235 Trigger Replacement: étape 2, image 2 de 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Trigger Replacement, Trigger: étape 3, image 1 de 2 Ryobi P235 Trigger Replacement, Trigger: étape 3, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Trigger Replacement: étape 4, image 1 de 2 Ryobi P235 Trigger Replacement: étape 4, image 2 de 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Trigger Replacement: étape 5, image 1 de 2 Ryobi P235 Trigger Replacement: étape 5, image 2 de 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Trigger Replacement: étape 6, image 1 de 2 Ryobi P235 Trigger Replacement: étape 6, image 2 de 2
    • Lift the trigger mechanism and other internal components out of the housing assembly.
  7. Ryobi P235 Trigger Replacement: étape 7, image 1 de 3 Ryobi P235 Trigger Replacement: étape 7, image 2 de 3 Ryobi P235 Trigger Replacement: étape 7, image 3 de 3
    • Use a soldering iron to remove the black and red wires connecting the trigger assembly to the motor.
    • Use the soldering iron to connect the new trigger assembly to the motor.
    • Make sure the red wire connects to the lead with the red mark on it.
To reassemble your device, follow these instructions in reverse order starting at step 6.
2 autres ont terminé cette réparation.
Paul Sousa
Membre depuis le 10/29/19
805 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 Membre de l'équipe UMass Dartmouth, Team S4-G2, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G2
3 membres
6 tutoriels rédigés
Un commentaire
Is the trigger what makes this a brushless motor? Is it possible for the trigger to cause the battery to drain down completely overnight?
Netgazer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 1,300
