Aller au contenu principal
Ryobi P501G Battery Replacement
  1. Ryobi P501G Battery Replacement, Battery: étape 1, image 1 de 1
    • Locate the battery at the base of the RYOBI P501G.
  2. Ryobi P501G Battery Replacement: étape 2, image 1 de 3 Ryobi P501G Battery Replacement: étape 2, image 2 de 3 Ryobi P501G Battery Replacement: étape 2, image 3 de 3
    • Place your thumb and forefinger on opposite sides at the base of the RYOBI P501G, where the buttons to release the battery are located.
    • Click on the buttons to release the latches holding the battery in place and connected.
Eeshan Mishra
Membre depuis le 01/24/19
424 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S1-G2, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 membres
7 tutoriels rédigés
Un commentaire
Replacement for Ryobi P501G Cordless Drill Battery
Type: Li-ion
Volt: 18V
Capacity: 6000mAh
Color: Black
Weight: 898g
Dimension: 135.70 x 76.00 x 107.30mm
This drill battery for Ryobi P501G is 100% compatible and will meet or exceeds original specification. This P501G replacement battery made by Amstron has been tested for safety and designed for high performance. go to view more at https://www.drillbattery.co.uk/batterysa...
Drillbatterycomau - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 18
Total : 471
