Aller au contenu principal
Ryobi P501G Motor Replacement
Ce dont vous avez besoin
  1. Ryobi P501G Motor Replacement, Motor: étape 1, image 1 de 1
    • Locate the screws at the top face of the saw, on the green plastic surface covering.
  2. Ryobi P501G Motor Replacement: étape 2, image 1 de 2 Ryobi P501G Motor Replacement: étape 2, image 2 de 2
    • Locate the eight outer screws of the plastic green encasement. They are marked in red in the picture.
    • Using a T15 torx screwdriver, unscrew all the holes, taking care not to lose any!
  3. Ryobi P501G Motor Replacement: étape 3, image 1 de 2 Ryobi P501G Motor Replacement: étape 3, image 2 de 2
    • Open up the top side of the encasement to reveal the internal parts of the saw.
    • Locate the motor.
  4. Ryobi P501G Motor Replacement: étape 4, image 1 de 2 Ryobi P501G Motor Replacement: étape 4, image 2 de 2
    • Using the T15 torx screwdriver, unscrew all four of the screws to free the motor from the encasement.
  5. Ryobi P501G Motor Replacement: étape 5, image 1 de 1
    • Remove the motor and replace with a new one if needed.
    • Be careful when handling the motor- it may be very dirty/greasy. You might want to wear gloves for this step!
Sophia Arias
Membre depuis le 04/21/19
255 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S1-G2, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 37
Total : 1,866
