Aller au contenu principal
Ryobi P501G Shell Replacement
Ce dont vous avez besoin
  1. Ryobi P501G Shell Replacement, Blade: étape 1, image 1 de 1
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: étape 2, image 1 de 2 Ryobi P501G Shell Replacement: étape 2, image 2 de 2
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: étape 3, image 1 de 3 Ryobi P501G Shell Replacement: étape 3, image 2 de 3 Ryobi P501G Shell Replacement: étape 3, image 3 de 3
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: étape 4, image 1 de 1
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: étape 5, image 1 de 3 Ryobi P501G Shell Replacement, Shell: étape 5, image 2 de 3 Ryobi P501G Shell Replacement, Shell: étape 5, image 3 de 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: étape 6, image 1 de 3 Ryobi P501G Shell Replacement: étape 6, image 2 de 3 Ryobi P501G Shell Replacement: étape 6, image 3 de 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
Eeshan Mishra
Membre depuis le 01/24/19
424 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S1-G2, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 290
