Aller au contenu principal
Ryobi P501G Trigger Replacement
Ce dont vous avez besoin
  1. Ryobi P501G Trigger Replacement, Shell: étape 1, image 1 de 3 Ryobi P501G Trigger Replacement, Shell: étape 1, image 2 de 3 Ryobi P501G Trigger Replacement, Shell: étape 1, image 3 de 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  2. Ryobi P501G Trigger Replacement: étape 2, image 1 de 3 Ryobi P501G Trigger Replacement: étape 2, image 2 de 3 Ryobi P501G Trigger Replacement: étape 2, image 3 de 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
  3. Ryobi P501G Trigger Replacement, Trigger: étape 3, image 1 de 1
    • After opening the shell, locate the black plastic trigger on the handle of the device.
  4. Ryobi P501G Trigger Replacement: étape 4, image 1 de 1
    • Remove the black wiring and the trigger is free! Reposition it however you'd like or switch it out with a new one.
    • Make sure the trigger is snug and exactly where you want it. A dislodged trigger can be very dangerous in a power saw!
Sophia Arias
Membre depuis le 04/21/19
255 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S1-G2, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 16
Total : 1,635
