Aller au contenu principal
Ryobi P516 Top Case Replacement
Ce dont vous avez besoin
  1. Ryobi P516 Top Case Replacement, Top Case: étape 1, image 1 de 2 Ryobi P516 Top Case Replacement, Top Case: étape 1, image 2 de 2
    • Using the 5mm hex key included at the base of the saw, loosen the set screw at the front of the saw.
    • The front guard will now slide out from the front of the saw.
  2. Ryobi P516 Top Case Replacement: étape 2, image 1 de 3 Ryobi P516 Top Case Replacement: étape 2, image 2 de 3 Ryobi P516 Top Case Replacement: étape 2, image 3 de 3
    • Remove the two 10mm T20 Torx screws from the front of the saw.
    • Pull out the front plate.
  3. Ryobi P516 Top Case Replacement: étape 3, image 1 de 3 Ryobi P516 Top Case Replacement: étape 3, image 2 de 3 Ryobi P516 Top Case Replacement: étape 3, image 3 de 3
    • Start at the middle of the device and begin to pry up the rubber grip.
    • Pull the rubber portion inside out towards the front of the saw.
  4. Ryobi P516 Top Case Replacement: étape 4, image 1 de 1
    • Remove all twelve 14mm T20 Torx screws from the main case of the device.
  5. Ryobi P516 Top Case Replacement: étape 5, image 1 de 3 Ryobi P516 Top Case Replacement: étape 5, image 2 de 3 Ryobi P516 Top Case Replacement: étape 5, image 3 de 3
    • Remove the four 35mm Phillips #2 screws.
    • Pry the two case halves apart starting at the middle of the saw.
    • Watch out for any loose parts from inside the saw that may fall out during this step.
  6. Ryobi P516 Top Case Replacement: étape 6, image 1 de 1
    • Continue splitting the case until the top piece of the case is free and set it aside.
6 autres ont terminé cette réparation.
2 commentaires
P516 blade locking parts
Bill clark - Réponse
P516 blade locking parts breakdown, please ?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 16
30 derniers jours : 78
Total : 4,210
