Aller au contenu principal
Ryobi RJ1861V Motor Replacement
Ce dont vous avez besoin
  1. Ryobi RJ1861V Motor Replacement, Saw Bar Assembly: étape 1, image 1 de 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Motor Replacement: étape 2, image 1 de 2 Ryobi RJ1861V Motor Replacement: étape 2, image 2 de 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Motor Replacement: étape 3, image 1 de 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Motor Replacement: étape 4, image 1 de 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Motor Replacement: étape 5, image 1 de 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Motor Replacement: étape 6, image 1 de 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Motor Replacement: étape 7, image 1 de 1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Motor Replacement, Assembly Bar Bearing: étape 8, image 1 de 1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Motor Replacement: étape 9, image 1 de 1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Motor Replacement: étape 10, image 1 de 1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Motor Replacement, Motor: étape 11, image 1 de 1
    • The motor is divided into two sections, one attached to the gear case and one attached to the handle.
    • This arrow indicates the section attached to the gear case.
    • This arrow indicates the section attached to the handle.
  12. Ryobi RJ1861V Motor Replacement: étape 12, image 1 de 3 Ryobi RJ1861V Motor Replacement: étape 12, image 2 de 3 Ryobi RJ1861V Motor Replacement: étape 12, image 3 de 3
    • Use a Torx T5 screwdriver to remove the four screws attaching the motor to the gear case.
  13. Ryobi RJ1861V Motor Replacement: étape 13, image 1 de 1
    • Use a Torx T5 screwdriver to remove the two screws inside the motor housing of the handle.
  14. Ryobi RJ1861V Motor Replacement: étape 14, image 1 de 2 Ryobi RJ1861V Motor Replacement: étape 14, image 2 de 2
    • Remove the four screws on the back of the housing with a Torx T5 screwdriver.
    • Flip the housing over and pull the motor up and out of the housing.
Adrian Williams
Membre depuis le 04/08/19
183 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 29
Total : 259
