Aller au contenu principal
Ryobi RJ1861V Saw Bar Assembly Replacement
Ce dont vous avez besoin
  1. Ryobi RJ1861V Saw Bar Assembly Replacement, Saw Bar Assembly: étape 1, image 1 de 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Saw Bar Assembly Replacement: étape 2, image 1 de 2 Ryobi RJ1861V Saw Bar Assembly Replacement: étape 2, image 2 de 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Saw Bar Assembly Replacement: étape 3, image 1 de 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Saw Bar Assembly Replacement: étape 4, image 1 de 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Saw Bar Assembly Replacement: étape 5, image 1 de 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Saw Bar Assembly Replacement: étape 6, image 1 de 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Saw Bar Assembly Replacement: étape 7, image 1 de 1
    • Lift the assembly bar up and out of the chassis.
Ryan Quinlivan
Membre depuis le 04/08/19
306 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 38
Total : 896
