Introduction
The fan in this blower is succeptible to breaking if small rocks or other small solid objects are sucked into the fan assembly. This guide outlines step-by-step how to replace this fan.
Ce dont vous avez besoin
Lay the blower on its side so that most of the screw heads are facing up. Identify all 9 screw locations.
One screw is located under the sticker with the number 8 on it.
Another screw is located on the opposite side.
Once the blower shaft is detached, the fan will be visible. Use a ratchet with a 1/2" socket to remove the 1/2" nut securing the fan to the motor. This nut is reverse thread so turning it clockwise will loosen it. The fan will also need to be secured so that it does not spin as the nut is being loosened.
Take leaf blower outside before operating to evaluate repair success.
2 autres ont terminé cette réparation.
7 commentaires
My blower is not like yours. Mine like a fun has corn shaped. How to replace this fun. I need your help.
Thanks for the tip, mine is a cordless 18 v and it's slightly more difficult then shown but not impossible!!
It's all plastic and kinda worried about breaking something. I've had mine like for almost 2 yrs. I was using it and barely bumped the wall and the blade just exploded….Really crazy weird.
Thanks for the help.
Cannot find the correct part on the internet anywhere. Mine is orange and flat on the back side; not coned & green as shown in your tutorial.
Jan Dru Basehart
Jan I believe mine was orange originally as well. I would try to contact their parts department to ensure it will work before ordering though.
