Introduction
The rubber seal inside the nose of the vacuum holds in loose dirt. If the seal is damaged, dirt may escape during use. This guide will help you replace the rubber seal inside of the nose of your vacuum.
Remove the nose of the vacuum and gently pull off the rubber seal by hand.
Presque terminé !
