Aller au contenu principal
SG 552-1 Commando Barrel Replacement
Ce dont vous avez besoin
  1. SG 552-1 Commando Barrel Replacement, Barrel: étape 1, image 1 de 2 SG 552-1 Commando Barrel Replacement, Barrel: étape 1, image 2 de 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: étape 2, image 1 de 2 SG 552-1 Commando Barrel Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: étape 3, image 1 de 2 SG 552-1 Commando Barrel Replacement: étape 3, image 2 de 2
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: étape 4, image 1 de 2 SG 552-1 Commando Barrel Replacement: étape 4, image 2 de 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: étape 5, image 1 de 2 SG 552-1 Commando Barrel Replacement: étape 5, image 2 de 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: étape 6, image 1 de 3 SG 552-1 Commando Barrel Replacement: étape 6, image 2 de 3 SG 552-1 Commando Barrel Replacement: étape 6, image 3 de 3
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: étape 7, image 1 de 2 SG 552-1 Commando Barrel Replacement: étape 7, image 2 de 2
    • Remove the remaining pieces of on the ends of the barrel.
Laura Schulz
Membre depuis le 10/05/12
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-41, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,673
