Aller au contenu principal
SG 552-1 Commando Safety Replacement
Ce dont vous avez besoin
  1. SG 552-1 Commando Safety Replacement, Gearbox: étape 1, image 1 de 2 SG 552-1 Commando Safety Replacement, Gearbox: étape 1, image 2 de 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Remove the hand guard.
  2. SG 552-1 Commando Safety Replacement: étape 2, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
    • There should be four total.
  3. SG 552-1 Commando Safety Replacement: étape 3, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 3, image 2 de 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw that is located directly underneath the cocking lever.
    • Remove the 8mm screw located beside the screw you just removed.
  4. SG 552-1 Commando Safety Replacement: étape 4, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 4, image 2 de 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  5. SG 552-1 Commando Safety Replacement: étape 5, image 1 de 3 SG 552-1 Commando Safety Replacement: étape 5, image 2 de 3 SG 552-1 Commando Safety Replacement: étape 5, image 3 de 3
    • Locate the hand grip.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
    • Slide the cover off.
  6. SG 552-1 Commando Safety Replacement: étape 6, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 6, image 2 de 2
    • Pull the motor out of the hand grip.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
  7. SG 552-1 Commando Safety Replacement: étape 7, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 7, image 2 de 2
    • Locate the pin holding the folding stock in place.
    • Using an allen wrench or something small, carefully push the pin out.
  8. SG 552-1 Commando Safety Replacement: étape 8, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 8, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
    • Remove the cover that was held on by the screw.
  9. SG 552-1 Commando Safety Replacement: étape 9, image 1 de 3 SG 552-1 Commando Safety Replacement: étape 9, image 2 de 3 SG 552-1 Commando Safety Replacement: étape 9, image 3 de 3
    • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
    • Slide off the piece that was held on by those screws.
  10. SG 552-1 Commando Safety Replacement: étape 10, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 10, image 2 de 2
    • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
    • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
  11. SG 552-1 Commando Safety Replacement: étape 11, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 11, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
    • Carefully remove the pieces that were held on by the screws.
  12. SG 552-1 Commando Safety Replacement: étape 12, image 1 de 3 SG 552-1 Commando Safety Replacement: étape 12, image 2 de 3 SG 552-1 Commando Safety Replacement: étape 12, image 3 de 3
    • Pull apart the cover when pulling the gearbox out.
    • Pull the gearbox out.
    • The gears will fall out when taking the gearbox out. Careful not to lose them.
  13. SG 552-1 Commando Safety Replacement, Safety: étape 13, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the single 3mm screw holding the safety/trigger cover in place.
  14. SG 552-1 Commando Safety Replacement: étape 14, image 1 de 2 SG 552-1 Commando Safety Replacement: étape 14, image 2 de 2
    • Remove the cover over the trigger.
    • The safety is located underneath the cover.
Anika Morris
Membre depuis le 10/05/12
1 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-41, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 703
