Introduction
This guide will be showing step-by-step instructions on how to get to and replace the spring of the airsoft gun.
Ce dont vous avez besoin
Using a flathead screwdriver, remove the pin holding the hand guard in place.
Remove the hand guard.
Using a Phillips #1 screwdriver, remove the following screws:
Remove these four 15mm screws.
Remove this single 8mm screw.
Using a Phillips #0 screwdriver, remove the following screws:
Remove this single 3mm screw.
Remove this single 14mm screw.
Detach the pieces unscrewed from the gearbox.
Un commentaire
When i read step 15 it seems impossible to up/downgrade spring without damaging the gun permanently??
