Aller au contenu principal
SHARP EL-546XT Battery Replacement
Ce dont vous avez besoin
  1. SHARP EL-546XT Battery Replacement, Battery: étape 1, image 1 de 2 SHARP EL-546XT Battery Replacement, Battery: étape 1, image 2 de 2
    • Place the calculator on a clean workspace with the back facing up.
  2. SHARP EL-546XT Battery Replacement: étape 2, image 1 de 3 SHARP EL-546XT Battery Replacement: étape 2, image 2 de 3 SHARP EL-546XT Battery Replacement: étape 2, image 3 de 3
    • Remove the calculator cover if you had it on.
    • Turn off the calculator using the 2nd F button then clicking the ON button.
  3. SHARP EL-546XT Battery Replacement: étape 3, image 1 de 3 SHARP EL-546XT Battery Replacement: étape 3, image 2 de 3 SHARP EL-546XT Battery Replacement: étape 3, image 3 de 3
    • Put the calculator cover back on to ensure you don't accidentally press any buttons.
    • Remove the screws from the battery door.
    • Do not remove the other screws as they are not for the battery compartment.
  4. SHARP EL-546XT Battery Replacement: étape 4, image 1 de 2 SHARP EL-546XT Battery Replacement: étape 4, image 2 de 2
    • Remove the battery door from the calculator.
  5. SHARP EL-546XT Battery Replacement: étape 5, image 1 de 3 SHARP EL-546XT Battery Replacement: étape 5, image 2 de 3 SHARP EL-546XT Battery Replacement: étape 5, image 3 de 3
    • Use a spudger to gently push the coin battery out through the small hole located below the battery.
    • Be careful not to apply too much force when pushing the old battery out to avoid damaging the calculator or the battery compartment.
  6. SHARP EL-546XT Battery Replacement: étape 6, image 1 de 3 SHARP EL-546XT Battery Replacement: étape 6, image 2 de 3 SHARP EL-546XT Battery Replacement: étape 6, image 3 de 3
    • Gently insert the new battery into the battery compartment.
    • Handle the new batteries with care.
  7. SHARP EL-546XT Battery Replacement: étape 7, image 1 de 2 SHARP EL-546XT Battery Replacement: étape 7, image 2 de 2
    • Ensure the battery is properly slotted in the battery compartment.
    • Close the battery compartment with the battery door.
  8. SHARP EL-546XT Battery Replacement: étape 8, image 1 de 3 SHARP EL-546XT Battery Replacement: étape 8, image 2 de 3 SHARP EL-546XT Battery Replacement: étape 8, image 3 de 3
    • Attach the screws back to the battery door.
  9. SHARP EL-546XT Battery Replacement: étape 9, image 1 de 3 SHARP EL-546XT Battery Replacement: étape 9, image 2 de 3 SHARP EL-546XT Battery Replacement: étape 9, image 3 de 3
    • Take the calculator out of the cover.
    • Turn on the calculator and test if it's functioning.
Ligne d'arrivée
Mithunan Sivagnanam
Membre depuis le 05/22/23
169 Réputation
1 tutoriel rédigé
Équipe
York University, Team A-11, Allen Summer 2023 Membre de l'équipe York University, Team A-11, Allen Summer 2023
YORK-ALLEN-SU23SAG11
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 20
Total : 503
