Aller au contenu principal
SIM Card Slot Repair
Ce dont vous avez besoin
  1. SIM Card Slot Repair, SIM Card Slot Repair: étape 1, image 1 de 3 SIM Card Slot Repair, SIM Card Slot Repair: étape 1, image 2 de 3 SIM Card Slot Repair, SIM Card Slot Repair: étape 1, image 3 de 3
    • Start by getting your work space set up and clear of clutter.
    • Remove the back of the phone.
    • Remove the battery and set it aside.
  2. SIM Card Slot Repair: étape 2, image 1 de 2 SIM Card Slot Repair: étape 2, image 2 de 2
    • Remove the six 2.3mm screws with a "T5" Screwdriver.
    • Remove the 2 additional 2.3mm screws from the side opposite the volume and power button.
    • When you open the back of the phone the camera and speaker will be attached to the part that you are removing.
  3. SIM Card Slot Repair: étape 3, image 1 de 3 SIM Card Slot Repair: étape 3, image 2 de 3 SIM Card Slot Repair: étape 3, image 3 de 3
    • Inspect the sim slot to find where the factory solder might be broken.
    • Once found dip the soldering gun in the flux to prevent the solder sticking to the gun.
    • Use the 60/40 lead solder to repair the damaged spot on the sim slot.
    • Do NOT allow the solder to touch any other connections as it could cause the device to short out or no function properly.
2 autres ont terminé cette réparation.
Cyndal Burns
Membre depuis le 06/02/17
155 Réputation
1 tutoriel rédigé
Un commentaire
I recently purchased a custom built phone which has the best parts of Android with the IMAX 13 camera my SIM tray broke and I can't seem to find anyone that has or knows which kind goes here is there any way you could help me
Bryan S. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 130
Total : 12,541
