Aller au contenu principal
SMD resistors organizer
  1. SMD resistors organizer, origami pocket (step1): étape 1, image 1 de 3 SMD resistors organizer, origami pocket (step1): étape 1, image 2 de 3 SMD resistors organizer, origami pocket (step1): étape 1, image 3 de 3
    • cut a square paper
  2. SMD resistors organizer, origami pocket (step2): étape 2, image 1 de 3 SMD resistors organizer, origami pocket (step2): étape 2, image 2 de 3 SMD resistors organizer, origami pocket (step2): étape 2, image 3 de 3
  3. SMD resistors organizer, origami pocket (step2): étape 3, image 1 de 3 SMD resistors organizer, origami pocket (step2): étape 3, image 2 de 3 SMD resistors organizer, origami pocket (step2): étape 3, image 3 de 3
    • continue the pocket
  4. SMD resistors organizer, origami pocket (step2): étape 4, image 1 de 2 SMD resistors organizer, origami pocket (step2): étape 4, image 2 de 2
    • finish the pocket
  5. SMD resistors organizer, prepare the sheets of values (step1): étape 5, image 1 de 3 SMD resistors organizer, prepare the sheets of values (step1): étape 5, image 2 de 3 SMD resistors organizer, prepare the sheets of values (step1): étape 5, image 3 de 3
    • even sheet with: 10, 12, 15, 18, 22, 27
    • odd sheets with: 33, 39, 47, 56, 68, 82
    • mark the pocket and put tape on long sides
  6. SMD resistors organizer, prepare the sheets of values (step2): étape 6, image 1 de 2 SMD resistors organizer, prepare the sheets of values (step2): étape 6, image 2 de 2
    • tape the pocket on the right sheet.
    • place the sheet in a usual plastic pocket to prevent the paper pocket to open!
  7. SMD resistors organizer, make sheets for each range of values: étape 7, image 1 de 2 SMD resistors organizer, make sheets for each range of values: étape 7, image 2 de 2
    • for E12 series, each range of power of 10 can be divided in 2 sheets of 6 pockets.
    • But you can decide to use the same technique to organize E24 resistors, you just need 4 sheets/range.
Flavien Driard
Membre depuis le 02/11/21
391 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 43
