Aller au contenu principal
SOMNOcomfort and SOMNObalance Ventilator Filter Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
  1. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement, Filter: étape 1, image 1 de 1
    • Locate the Filter Compartment on the back of the ventilator.
  2. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: étape 2, image 1 de 1
    • Push the compartment cover (22) up (from the bottom)
  3. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: étape 3, image 1 de 1
    • Remove the coarse dust filter(68)
  4. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: étape 4, image 1 de 1
    • Remove the fine dust filter(67)
    • Replace the filters and close the cover on the rear of the unit.
  5. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: étape 6, image 1 de 1
    • Reset the filter change indicator by pressing and holding the on/off switch(19) until the filter change indicator goes blank.
    • If the fine filter was changed due to soiling before 250 operating hours, the hours meter must be reset to zero. Proceed as follows:
    • When switching the unit on, press and hold the on/off switch 19. The filter change indicator will come on after about three seconds before going off again after another three seconds. Release the on and off switch.
Diya Jamwal
Membre depuis le 11/07/18
553 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Membre de l'équipe Cal Poly, Team S1-G3, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G3
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 139
