Aller au contenu principal
SPOT X SPOTXB Motherboard Replacement
Ce dont vous avez besoin
  1. SPOT X SPOTXB Motherboard Replacement, Back Cover: étape 1, image 1 de 3 SPOT X SPOTXB Motherboard Replacement, Back Cover: étape 1, image 2 de 3 SPOT X SPOTXB Motherboard Replacement, Back Cover: étape 1, image 3 de 3
    • Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
  2. SPOT X SPOTXB Motherboard Replacement: étape 2, image 1 de 1
    • Remove the seven 4.1 mm screws from the back of the device using a T4 Torx screwdriver.
  3. SPOT X SPOTXB Motherboard Replacement: étape 3, image 1 de 1
    • Gently separate the back cover from the rest of the device.
  4. SPOT X SPOTXB Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • Remove the ten 2.9 mm screws from the motherboard using a T5 Torx screwdriver.
    • Carefully remove the motherboard, as it is connected to the battery underneath.
  5. SPOT X SPOTXB Motherboard Replacement: étape 5, image 1 de 1
    • Desolder the battery cables from the motherboard.
    • Separate the motherboard from the rest of the device.
Kristen Gismondi
Membre depuis le 11/12/14
99 333 Réputation
255 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 618 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 93
