Aller au contenu principal
SR405QM Battery Replacement
Ce dont vous avez besoin
  1. SR405QM Battery Replacement, Battery: étape 1, image 1 de 1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. SR405QM Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. SR405QM Battery Replacement: étape 3, image 1 de 2 SR405QM Battery Replacement: étape 3, image 2 de 2
    • Remove the cap by lifting upwards to reveal the battery.
  4. SR405QM Battery Replacement: étape 4, image 1 de 3 SR405QM Battery Replacement: étape 4, image 2 de 3 SR405QM Battery Replacement: étape 4, image 3 de 3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
To reassemble your device, follow these instructions in reverse order with a fresh battery.
2 autres ont terminé cette réparation.
Chris Pittner
Membre depuis le 01/11/13
220 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-18, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 4
Total : 1,153
