Aller au contenu principal
SVP 5800 Front Casing Replacement
Ce dont vous avez besoin
  1. SVP 5800 Front Casing Replacement, Strap Hook: étape 1, image 1 de 3 SVP 5800 Front Casing Replacement, Strap Hook: étape 1, image 2 de 3 SVP 5800 Front Casing Replacement, Strap Hook: étape 1, image 3 de 3
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. SVP 5800 Front Casing Replacement, Front Casing: étape 2, image 1 de 2 SVP 5800 Front Casing Replacement, Front Casing: étape 2, image 2 de 2
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. SVP 5800 Front Casing Replacement: étape 3, image 1 de 2 SVP 5800 Front Casing Replacement: étape 3, image 2 de 2
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  4. SVP 5800 Front Casing Replacement: étape 4, image 1 de 2 SVP 5800 Front Casing Replacement: étape 4, image 2 de 2
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
Cheyenne Heinen
Membre depuis le 03/07/16
358 Réputation
3 tutoriels rédigés
Équipe
Marist, Team 1-3, Laflen Spring 2016 Membre de l'équipe Marist, Team 1-3, Laflen Spring 2016
MARS-LAFLEN-S16S1G3
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 279
