Introduction
The gasket of the brewing unit has to withstand heavy usage. Especially the large O-Ring on the piston needs replacing from time to time. Follow this guide to replace the gasket.
Note: The images show the brewing unit of a Saeco Minuto and may may differ slightly, but the procedure is basically the same.
Ce dont vous avez besoin
You can push out the lower piston from the brewing unit if you snap the deflection lever out of its socket with a screw driver.
Clean all parts with very hot water and dishwasher liquid.
Grease all moving parts with food grade silicone fat. Dont forget the tracks in the side panels.
Follow the steps in reverse order to reassemble your device.
Merci à ces traducteurs :
100%
VauWeh nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
