Aller au contenu principal
Saeco Incanto SBS Piston Head Seals / O-rings Replacement
Ce dont vous avez besoin
  1. Saeco Incanto SBS Piston Head Seals / O-rings Replacement, Piston Head Seals / O-rings: étape 1, image 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement, Piston Head Seals / O-rings: étape 1, image 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement, Piston Head Seals / O-rings: étape 1, image 3 de 3
    • I show you the O-rings in the top piston of the brewgroup. I don't write much, because my english is bad, but the photos speak for themselves. Good luck
    • Two screws, PZ 1
    • Careful, there is a spring.
  2. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 2, image 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 2, image 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 2, image 3 de 3
    • Spring, O-ring and a GLASBALL.
  3. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 3, image 1 de 1
    • Ja
  4. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 4, image 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 4, image 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 4, image 3 de 3
    • Remove the piston. More information in my guide " Disassembling & Cleaning the Brewgroup" here.
  5. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 5, image 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 5, image 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 5, image 3 de 3
    • Screw PZ 1
    • Counterrotate turning the screw.
    • Then pull that thing and you find another seal
  6. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 6, image 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 6, image 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 6, image 3 de 3
    • Details
  7. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 7, image 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 7, image 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 7, image 3 de 3
    • Tools for cleaning, ja toothbrush
  8. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 8, image 1 de 2 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 8, image 2 de 2
    • There are two types of O-rings. For this type of piston you need the smaller.
  9. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 9, image 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 9, image 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 9, image 3 de 3
    • Grease it a liitle.
    • Just put it back, no problem.
  10. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: étape 10, image 1 de 1
    • ...and then I found a crack in my piston. That can not be repaired. So I had to buy a new piston.
4 autres ont terminé cette réparation.
Schwarzstein
Membre depuis le 07/15/13
2 847 Réputation
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 31
Total : 3,688
