Aller au contenu principal
Samsung SmartCam HD Pro Casing Replacement
Ce dont vous avez besoin
  1. Samsung  SmartCam HD Pro Casing Replacement, Casing: étape 1, image 1 de 1
    • Locate a small opening around the front panel of the camera.
  2. Samsung  SmartCam HD Pro Casing Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung  SmartCam HD Pro Casing Replacement: étape 3, image 1 de 1
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung  SmartCam HD Pro Casing Replacement: étape 4, image 1 de 1
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung  SmartCam HD Pro Casing Replacement: étape 5, image 1 de 1
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
AllisonBridges
Membre depuis le 01/18/17
501 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 662
