Pièces
Aucune pièce nécessaire.
  1. Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Avez-vous jamais réparé quelque chose ? C’est génial.
    Share your repair story with #ImAGenius
    Nous sommes tous des génies
  3. Locate the wireless card.  It is shown highlighted in picture one. Detach the black and white cords connected to the wireless card and unscrew the screw holding in the card.  They are shown highlighted in picture two. Pull the card out of its slot and insert the new card.  Reattach the wires and reassemble the device.  Note: the white wire connects to the terminal closer to the screw and the black to the other terminal.
    • Locate the wireless card. It is shown highlighted in picture one.
    • Detach the black and white cords connected to the wireless card and unscrew the screw holding in the card. They are shown highlighted in picture two.
    • Pull the card out of its slot and insert the new card. Reattach the wires and reassemble the device. Note: the white wire connects to the terminal closer to the screw and the black to the other terminal.
Garrett Kissinger
Membre depuis le 24/02/2014
692 Réputation
5 tutoriels rédigés
Équipe
Michigan Tech, Team 1-2, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 1,299
