Aller au contenu principal
Samsung ATIV Book 4 Battery Replacement
Ce dont vous avez besoin
  1. Samsung ATIV Book 4 Battery Replacement, Battery: étape 1, image 1 de 2 Samsung ATIV Book 4 Battery Replacement, Battery: étape 1, image 2 de 2
    • Place the computer upside down.
    • Remove 2 rubber pads, by prying up on them.
    • There may be adhesive holding them down. If this is the case, the plastic opening tool may be needed to remove them.
    • Remove the seven 6.5mm screws on exterior of computer.
  2. Samsung ATIV Book 4 Battery Replacement: étape 2, image 1 de 2 Samsung ATIV Book 4 Battery Replacement: étape 2, image 2 de 2
    • Remove the panel by sliding it down and lifting it away from the computer.
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Battery Replacement: étape 3, image 1 de 2 Samsung ATIV Book 4 Battery Replacement: étape 3, image 2 de 2
    • Using the plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer, once all tabs are broken free.
  4. Samsung ATIV Book 4 Battery Replacement: étape 4, image 1 de 1
    • Remove the four 3.5mm screws holding the battery.
    • Peel back the tape securing the wires to the battery.
    • Lift and remove the battery from its location.
    • Don't pull/tear the wires connected to battery harness.
  5. Samsung ATIV Book 4 Battery Replacement: étape 5, image 1 de 1
    • Disconnect the battery harness from computer.
    • Completely remove the battery and replace it.
  6. Samsung ATIV Book 4 Battery Replacement: étape 6, image 1 de 1
    • Plug battery harness back in.
    • Assure the wires are pointed up (towards you) then plugging back in, as shown.
4 autres ont terminé cette réparation.
Chad
Membre depuis le 03/17/15
437 Réputation
2 tutoriels rédigés
Équipe
Michigan Tech, Team 1-7, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-7, Lauer Spring 2015
MTU-LAUER-S15S1G7
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 27
Total : 9,682
