Aller au contenu principal
Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement
Ce dont vous avez besoin
  1. Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement, Backplate: étape 1, image 1 de 2 Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement, Backplate: étape 1, image 2 de 2
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement: étape 2, image 1 de 1
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement, Touch-Screen: étape 3, image 1 de 1
    • Disconnect the databus from the motherboard as seen in the lower left of the picture
    • Disconnect the white and black wire from the graphics card as seen in the middle of the photo. (Note: These two wires are connected to the motherboard by means of snap-in male-female copper connectors, meaning they can be disconnected by un-snapping the connectors.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement: étape 4, image 1 de 1
    • Using the Phillips #000 screwdriver, remove six 5mm screws.
    • These screws hold the screen assembly into place with the motherboard / electronics assembly.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement: étape 5, image 1 de 1
    • Now that the six 5mm screws were removed, remove and separate the screen assembly as seen in the image.
    • As seen in the next step, the backplate of the screen assembly will be removed. There is no hardware keeping this in place except for adhesive glue. Therefore the screen assembly backplate will be gently pried free.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement: étape 6, image 1 de 1
    • The screen assembly backplate is to be removed
    • The backplate is adhered around the edges. Using a flat-wedged tool, gently pry the backplate free from the assembly.
  7. Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement: étape 7, image 1 de 2 Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement: étape 7, image 2 de 2
    • Now that backplate has been removed, flip the laptop over on the front. Remove the capacitive touch screen.
    • Similarly to how the backplate was adhered with glue, this touch screen is adhered to the graphics screen of this device. As seen in the second photo, the touch screen should be gently separated from the graphics screen. Make sure to disconnect the ribbon as circle in the photo.
  8. Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement, Graphics-Screen: étape 8, image 1 de 2 Samsung ATIV Book 7 NP740U3E-K01UB Graphics-Screen Replacement, Graphics-Screen: étape 8, image 2 de 2
    • Remove the six 3 mm screws using the Phillips #000 screwdriver.
    • This will free the graphics-screen from the holding assembly as seen in the second photo.
    • Unhook the ribbon connection.
    • Remove the screen.
Important Note: When re-assembling the screen assembly, additional adhesive glue may be needed to adhere the graphic-screen, capacitive touch-screen and screen cover back onto the original assembly.
Liam
Membre depuis le 03/26/19
223 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G5, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G5
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 715
