Introduction
This guide will show you how to replace the board containing the USB ports and the SD card reader on your laptop.
Ce dont vous avez besoin
Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
Disconnect the ribbon connecting the motherboard with the USB ports .
Disconnect the speaker from the board
Presque terminé !
