Aller au contenu principal
Samsung ATIV Book 9 Lite Battery Replacement
Ce dont vous avez besoin
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: étape 1, image 1 de 2 Samsung ATIV Book 9 Lite Battery Replacement, Battery: étape 1, image 2 de 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: étape 2, image 1 de 3 Samsung ATIV Book 9 Lite Battery Replacement: étape 2, image 2 de 3 Samsung ATIV Book 9 Lite Battery Replacement: étape 2, image 3 de 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: étape 3, image 1 de 3 Samsung ATIV Book 9 Lite Battery Replacement: étape 3, image 2 de 3 Samsung ATIV Book 9 Lite Battery Replacement: étape 3, image 3 de 3
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: étape 4, image 1 de 2 Samsung ATIV Book 9 Lite Battery Replacement: étape 4, image 2 de 2
    • Using your hands remove the battery from the computer.
3 autres ont terminé cette réparation.
Phat Tran
Membre depuis le 09/16/18
786 Réputation
5 tutoriels rédigés
Équipe
Washington State, Team S2-G5, Hope Fall 2018 Membre de l'équipe Washington State, Team S2-G5, Hope Fall 2018
WSU-HOPE-F18S2G5
4 membres
5 tutoriels rédigés
2 commentaires
please where can i get the battery 🔋
Bethel Ugwudike - Réponse
Please where can i get the battery for Samsung 930x5j910s5j940x5j
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 22
Total : 1,691
