Aller au contenu principal
Samsung ATIV Book 9 Lite Hard Drive Replacement
Ce dont vous avez besoin
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: étape 2, image 1 de 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: étape 2, image 2 de 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: étape 2, image 3 de 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: étape 3, image 1 de 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: étape 3, image 2 de 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: étape 3, image 3 de 3
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: étape 4, image 1 de 2 Samsung ATIV Book 9 Lite Hard Drive Replacement: étape 4, image 2 de 2
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
2 autres ont terminé cette réparation.
Phat Tran
Membre depuis le 09/16/18
786 Réputation
5 tutoriels rédigés
Équipe
Washington State, Team S2-G5, Hope Fall 2018 Membre de l'équipe Washington State, Team S2-G5, Hope Fall 2018
WSU-HOPE-F18S2G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 53
Total : 4,584
