Aller au contenu principal
Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
Ce dont vous avez besoin
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: étape 1, image 1 de 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: étape 1, image 2 de 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: étape 1, image 3 de 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: étape 2, image 1 de 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: étape 3, image 1 de 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: étape 3, image 2 de 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: étape 3, image 3 de 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: étape 4, image 1 de 2 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: étape 4, image 2 de 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: étape 5, image 1 de 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: étape 6, image 1 de 1
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: étape 7, image 1 de 1
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: étape 8, image 1 de 1
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
Ryan Smith
Membre depuis le 04/01/19
193 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S7-G7, Wilson Spring 2019 Membre de l'équipe IUPUI, Team S7-G7, Wilson Spring 2019
IUPUI-WILSON-S19S7G7
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 638
