Aller au contenu principal
Samsung ATIV Book 9 Plus Internal Fans Replacement
Ce dont vous avez besoin
  1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: étape 1, image 1 de 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: étape 1, image 2 de 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: étape 1, image 3 de 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Internal Fans Replacement: étape 2, image 1 de 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: étape 3, image 1 de 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: étape 3, image 2 de 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: étape 3, image 3 de 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Internal Fans Replacement: étape 4, image 1 de 2 Samsung ATIV Book 9 Plus Internal Fans Replacement: étape 4, image 2 de 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Internal Fans Replacement: étape 5, image 1 de 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
2 autres ont terminé cette réparation.
Rhannie Surel
Membre depuis le 03/20/15
137 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team 2-3, Grigsby Spring 2015 Membre de l'équipe Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 membres
4 tutoriels rédigés
Un commentaire
I think that's to easy!
Ocean - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 4,465
