Aller au contenu principal
Samsung ATIV Book 9 Plus Screen Replacement
Ce dont vous avez besoin
  1. Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: étape 1, image 1 de 3 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: étape 1, image 2 de 3 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: étape 1, image 3 de 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Screen Replacement: étape 2, image 1 de 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Screen Replacement, Screen: étape 3, image 1 de 1
    • Disconnect the wire connected at the marked location. This is done by giving it a solid tug parallel with the laptop.
  4. Samsung ATIV Book 9 Plus Screen Replacement: étape 4, image 1 de 2 Samsung ATIV Book 9 Plus Screen Replacement: étape 4, image 2 de 2
    • Unscrew the three 4.3 mm screws by using a #000 screwdriver located on the hinges in both corners of the laptop.
  5. Samsung ATIV Book 9 Plus Screen Replacement: étape 5, image 1 de 2 Samsung ATIV Book 9 Plus Screen Replacement: étape 5, image 2 de 2
    • Remove the piece of foam that covers two antenna cable connectors.
    • Use the tip of a spudger or a fingernail to pry straight up and disconnect the antenna cable connectors.
  6. Samsung ATIV Book 9 Plus Screen Replacement: étape 6, image 1 de 1
    • Now the screen is completely disconnected and can just be lifted off.
Casey Kauffman
Membre depuis le 11/06/17
329 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S6-G6, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 2,171
