Aller au contenu principal
Samsung Admire Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Admire Speaker Replacement, Back Cover: étape 1, image 1 de 1
    • Use your fingernail or plastic opening tool to pull up the back cover of the phone from under the slit.
  2. Samsung Admire Speaker Replacement, Remove the battery: étape 2, image 1 de 1
    • Carefully remove the battery by placing your fingernail underneath the hole and pulling out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Speaker Replacement, Remove the screws: étape 3, image 1 de 3 Samsung Admire Speaker Replacement, Remove the screws: étape 3, image 2 de 3 Samsung Admire Speaker Replacement, Remove the screws: étape 3, image 3 de 3
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  4. Samsung Admire Speaker Replacement, Inside back cover: étape 4, image 1 de 3 Samsung Admire Speaker Replacement, Inside back cover: étape 4, image 2 de 3 Samsung Admire Speaker Replacement, Inside back cover: étape 4, image 3 de 3
    • Use the plastic opening tools to remove the inside back cover.
    • Place the plastic opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Speaker Replacement, Speaker: étape 5, image 1 de 2 Samsung Admire Speaker Replacement, Speaker: étape 5, image 2 de 2
    • The speaker is located within the inside of the back cover.
    • Simply remove it by lifting it off with the plastic opening tool.
2 autres ont terminé cette réparation.
Thao Uyen Do
Membre depuis le 01/20/15
896 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 7-5, Remmell Winter 2015 Membre de l'équipe USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 23
Total : 733
