Introduction
No special requirements are necessary other than a PH2 head screwdriver. Following this guide should help the user fix any problems with powering on the device or the device not responding to discs.
Ce dont vous avez besoin
To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
Locate the motherboard within the red rectangle.
Locate the power supply within the orange rectangle.
The screws securing the motherboard in are labeled with red circles and the wires are labeled with orange rectangles.
Use your screwdriver with a PH2 sized head and unscrew these 1.2mm screws labeled with red circles.
Detach the wires connected the motherboard from the disc drive that are labeled in orange.
