Aller au contenu principal
Samsung BD-E5400 Power Cord Replacement
Ce dont vous avez besoin
  1. Samsung BD-E5400 Power Cord Replacement, Outer Cover: étape 1, image 1 de 2 Samsung BD-E5400 Power Cord Replacement, Outer Cover: étape 1, image 2 de 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Power Cord Replacement: étape 2, image 1 de 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Power Cord Replacement, Power Cord: étape 3, image 1 de 2 Samsung BD-E5400 Power Cord Replacement, Power Cord: étape 3, image 2 de 2
    • Remove the two 8 mm long, #1 Phillips head screws.
    • Lift up the plastic component cover to remove and lay aside.
  4. Samsung BD-E5400 Power Cord Replacement: étape 4, image 1 de 3 Samsung BD-E5400 Power Cord Replacement: étape 4, image 2 de 3 Samsung BD-E5400 Power Cord Replacement: étape 4, image 3 de 3
    • With the motherboard exposed, locate the point where the power cord is attached.
    • Separate the portion of the cord encased in the black grommet from the frame of the device.
    • Unplug the power cord from the motherboard.
Cameron Herring
Membre depuis le 08/28/18
306 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G3, Arle Fall 2018 Membre de l'équipe IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 335
