Aller au contenu principal
Samsung BD-F5700 Disc Reader Replacement
Ce dont vous avez besoin
  1. Samsung BD-F5700 Disc Reader Replacement, Power Cord: étape 1, image 1 de 3 Samsung BD-F5700 Disc Reader Replacement, Power Cord: étape 1, image 2 de 3 Samsung BD-F5700 Disc Reader Replacement, Power Cord: étape 1, image 3 de 3
    • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
    • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
    • When opening the device, be careful to not damage the ribbon cable circled in image 3.
  2. Samsung BD-F5700 Disc Reader Replacement: étape 2, image 1 de 3 Samsung BD-F5700 Disc Reader Replacement: étape 2, image 2 de 3 Samsung BD-F5700 Disc Reader Replacement: étape 2, image 3 de 3
    • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
    • Remove plastic cover from board.
  3. Samsung BD-F5700 Disc Reader Replacement: étape 3, image 1 de 2 Samsung BD-F5700 Disc Reader Replacement: étape 3, image 2 de 2
    • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
    • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  4. Samsung BD-F5700 Disc Reader Replacement: étape 4, image 1 de 1
    • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
    • Pull the tab off the wire so that it can be placed on the replacement cord.
  5. Samsung BD-F5700 Disc Reader Replacement, Disc Reader: étape 5, image 1 de 3 Samsung BD-F5700 Disc Reader Replacement, Disc Reader: étape 5, image 2 de 3 Samsung BD-F5700 Disc Reader Replacement, Disc Reader: étape 5, image 3 de 3
    • Firmly grip the hard plastic tab attached to the base and pull upwards.
    • It is important to not tear the ribbon cables.
  6. Samsung BD-F5700 Disc Reader Replacement: étape 6, image 1 de 2 Samsung BD-F5700 Disc Reader Replacement: étape 6, image 2 de 2
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  7. Samsung BD-F5700 Disc Reader Replacement: étape 7, image 1 de 3 Samsung BD-F5700 Disc Reader Replacement: étape 7, image 2 de 3 Samsung BD-F5700 Disc Reader Replacement: étape 7, image 3 de 3
    • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
  8. Samsung BD-F5700 Disc Reader Replacement: étape 8, image 1 de 3 Samsung BD-F5700 Disc Reader Replacement: étape 8, image 2 de 3 Samsung BD-F5700 Disc Reader Replacement: étape 8, image 3 de 3
    • Flip up the black locking tab on the ZIF connector.
  9. Samsung BD-F5700 Disc Reader Replacement: étape 9, image 1 de 3 Samsung BD-F5700 Disc Reader Replacement: étape 9, image 2 de 3 Samsung BD-F5700 Disc Reader Replacement: étape 9, image 3 de 3
    • Remove the 10 mm screw using a Phillips #1 screwdriver.
    • Remove the small metal bar by pulling it outwards.
  10. Samsung BD-F5700 Disc Reader Replacement: étape 10, image 1 de 2 Samsung BD-F5700 Disc Reader Replacement: étape 10, image 2 de 2
    • Flip the disc tray over so the laser points downward.
    • Pull the disc reader out of the disc tray.
2 autres ont terminé cette réparation.
Livan Perez
Membre depuis le 02/15/18
303 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S16-G4, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 25
Total : 704
