Aller au contenu principal
Samsung BD-F7500 Blu-ray Player Disc Tray Replacement
Ce dont vous avez besoin
  1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: étape 1, image 1 de 2 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: étape 1, image 2 de 2
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 2, image 1 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 2, image 2 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 2, image 3 de 3
    • To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
    • Be careful not to tear the ribbon cables.
  3. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 3, image 1 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 3, image 2 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 3, image 3 de 3
    • Using a screwdriver with a #J1 bit, remove the two (2) 7 mm screws.
  4. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 4, image 1 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 4, image 2 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: étape 4, image 3 de 3
    • Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
    • While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
James McMicheal
Membre depuis le 09/28/17
520 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 689
