Aller au contenu principal
Samsung BD-H5100 Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung BD-H5100 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Use the Phillips Head #2 screwdriver to remove the three 10mm screws on the back panel.
  2. Samsung BD-H5100 Motherboard Replacement: étape 2, image 1 de 3 Samsung BD-H5100 Motherboard Replacement: étape 2, image 2 de 3 Samsung BD-H5100 Motherboard Replacement: étape 2, image 3 de 3
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Motherboard Replacement: étape 3, image 1 de 2 Samsung BD-H5100 Motherboard Replacement: étape 3, image 2 de 2
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the two 7.5mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Motherboard Replacement: étape 5, image 1 de 2 Samsung BD-H5100 Motherboard Replacement: étape 5, image 2 de 2
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Motherboard Replacement: étape 6, image 1 de 2 Samsung BD-H5100 Motherboard Replacement: étape 6, image 2 de 2
    • Use a Phillips Head #2 to remove the two 7.5mm screws on the black cover.
    • Remove the black cover.
  7. Samsung BD-H5100 Motherboard Replacement: étape 7, image 1 de 2 Samsung BD-H5100 Motherboard Replacement: étape 7, image 2 de 2
    • Pinch the white clip and pull straight up on the power cord.
    • Remove the power cord.
  8. Samsung BD-H5100 Motherboard Replacement: étape 8, image 1 de 1
    • Use a Phillips Head #2 to remove the 7.5mm screw.
  9. Samsung BD-H5100 Motherboard Replacement: étape 9, image 1 de 1
    • Use your finger to pry the metal tab slightly up.
    • This may break after several uses.
  10. Samsung BD-H5100 Motherboard Replacement: étape 10, image 1 de 1
    • Slide out the Motherboard.
    • Be careful when touching the bottom because it is sharp.
Mira Patel
Membre depuis le 10/11/16
580 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-2, Leahy Fall 2016
USFT-LEAHY-F16S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 547
