Aller au contenu principal
Samsung Brightside Speaker Module Replacement
Ce dont vous avez besoin
  1. Samsung Brightside Speaker Module Replacement, Speaker Module: étape 1, image 1 de 3 Samsung Brightside Speaker Module Replacement, Speaker Module: étape 1, image 2 de 3 Samsung Brightside Speaker Module Replacement, Speaker Module: étape 1, image 3 de 3
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Speaker Module Replacement: étape 2, image 1 de 3 Samsung Brightside Speaker Module Replacement: étape 2, image 2 de 3 Samsung Brightside Speaker Module Replacement: étape 2, image 3 de 3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Speaker Module Replacement: étape 3, image 1 de 3 Samsung Brightside Speaker Module Replacement: étape 3, image 2 de 3 Samsung Brightside Speaker Module Replacement: étape 3, image 3 de 3
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Speaker Module Replacement: étape 4, image 1 de 3 Samsung Brightside Speaker Module Replacement: étape 4, image 2 de 3 Samsung Brightside Speaker Module Replacement: étape 4, image 3 de 3
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Speaker Module Replacement: étape 5, image 1 de 3 Samsung Brightside Speaker Module Replacement: étape 5, image 2 de 3 Samsung Brightside Speaker Module Replacement: étape 5, image 3 de 3
    • Detach the LCD connector.
    • Remove the logic board
    • This is the speaker module. In the center is the camera, but it is not part of the module.
  6. Samsung Brightside Speaker Module Replacement: étape 6, image 1 de 3 Samsung Brightside Speaker Module Replacement: étape 6, image 2 de 3 Samsung Brightside Speaker Module Replacement: étape 6, image 3 de 3
    • turn the logic board over. The speaker module is held in place
    • by one Phillips screw
    • and two clips
    • Remove the Phillips screw.
    • It is a M1X2 Phillips screw
    • Next disengage one of the clips by simply applying some sideways pressure with your fingernail. This will loosen the module.
  7. Samsung Brightside Speaker Module Replacement: étape 7, image 1 de 2 Samsung Brightside Speaker Module Replacement: étape 7, image 2 de 2
    • Turn the logic board around. With the speaker module loose, simply lift it off the board.
    • Speaker module removed.
    • Camera
    • and audio jack
    • are not part of this module and will remain on the board.
oldturkey03
Membre depuis le 09/29/10
791 325 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
35 membres
603 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 988
