Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Captivate Camera Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Captivate Camera Assembly Replacement, Battery: étape 1, image 1 de 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Captivate Camera Assembly Replacement: étape 2, image 1 de 1
    • Place your finger on the bottom of the battery and lift to remove.
    Demander à FixBot
  3. Samsung Captivate Camera Assembly Replacement: étape 3, image 1 de 1
    • Replace the old battery with the new one.
    Demander à FixBot
  4. Samsung Captivate Camera Assembly Replacement, Rear Case: étape 4, image 1 de 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
    Demander à FixBot
  5. Samsung Captivate Camera Assembly Replacement: étape 5, image 1 de 1
    • Remove the six 4.5mm #000 Phillips screws.
    Demander à FixBot
  6. Samsung Captivate Camera Assembly Replacement: étape 6, image 1 de 3 Samsung Captivate Camera Assembly Replacement: étape 6, image 2 de 3 Samsung Captivate Camera Assembly Replacement: étape 6, image 3 de 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
    Demander à FixBot
  7. Samsung Captivate Camera Assembly Replacement: étape 7, image 1 de 1
    • Separate the rear case from the phone.
    Demander à FixBot
  8. Samsung Captivate Camera Assembly Replacement, Camera Assembly: étape 8, image 1 de 1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
    Demander à FixBot
  9. Samsung Captivate Camera Assembly Replacement: étape 9, image 1 de 1
    • Gently lift the camera assembly out of the plastic housing.
    Demander à FixBot
3 autres ont terminé cette réparation.
Drew Bentz
Membre depuis le 09/22/11
565 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 20-25, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 membres
18 tutoriels rédigés
2 commentaires de tutoriel
Is this for the front facing camera
tracy mann - Réponse Partager
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 35
Total : 2,789
