Aller au contenu principal
Samsung Captivate Earpiece Replacement
Ce dont vous avez besoin
  1. Samsung Captivate Earpiece Replacement, Battery: étape 1, image 1 de 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Earpiece Replacement: étape 2, image 1 de 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Earpiece Replacement: étape 3, image 1 de 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Earpiece Replacement, Rear Case: étape 4, image 1 de 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Earpiece Replacement: étape 5, image 1 de 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Earpiece Replacement: étape 6, image 1 de 3 Samsung Captivate Earpiece Replacement: étape 6, image 2 de 3 Samsung Captivate Earpiece Replacement: étape 6, image 3 de 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Earpiece Replacement: étape 7, image 1 de 1
    • Separate the rear case from the phone.
  8. Samsung Captivate Earpiece Replacement, Antenna Cable: étape 8, image 1 de 2 Samsung Captivate Earpiece Replacement, Antenna Cable: étape 8, image 2 de 2
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate Earpiece Replacement, Camera Assembly: étape 9, image 1 de 1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  10. Samsung Captivate Earpiece Replacement: étape 10, image 1 de 1
    • Gently lift the camera assembly out of the plastic housing.
  11. Samsung Captivate Earpiece Replacement, Motherboard: étape 11, image 1 de 3 Samsung Captivate Earpiece Replacement, Motherboard: étape 11, image 2 de 3 Samsung Captivate Earpiece Replacement, Motherboard: étape 11, image 3 de 3
    • Using the spudger slide the tool under the three highlighted connectors to begin disconnection
    • Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
    • Be careful to not pry against the connector. Prying against could further damage to the device.
  12. Samsung Captivate Earpiece Replacement: étape 12, image 1 de 1
    • Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
  13. Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: étape 13, image 1 de 2 Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: étape 13, image 2 de 2
    • Gently pull up on the audio jack, taking the attached ribbon cable with it.
    • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
  14. Samsung Captivate Earpiece Replacement, Earpiece: étape 14, image 1 de 1
    • The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
2 autres ont terminé cette réparation.
Drew Bentz
Membre depuis le 09/22/11
565 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 20-25, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 2,379
