Aller au contenu principal
Samsung Captivate Glide Camera Replacement
Ce dont vous avez besoin
  1. Samsung Captivate Glide Camera Replacement, Motherboard: étape 1, image 1 de 3 Samsung Captivate Glide Camera Replacement, Motherboard: étape 1, image 2 de 3 Samsung Captivate Glide Camera Replacement, Motherboard: étape 1, image 3 de 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Camera Replacement: étape 2, image 1 de 2 Samsung Captivate Glide Camera Replacement: étape 2, image 2 de 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Camera Replacement: étape 3, image 1 de 2 Samsung Captivate Glide Camera Replacement: étape 3, image 2 de 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Camera Replacement: étape 4, image 1 de 3 Samsung Captivate Glide Camera Replacement: étape 4, image 2 de 3 Samsung Captivate Glide Camera Replacement: étape 4, image 3 de 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Camera Replacement: étape 5, image 1 de 2 Samsung Captivate Glide Camera Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Camera Replacement: étape 6, image 1 de 1
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Camera Replacement: étape 7, image 1 de 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Camera Replacement: étape 8, image 1 de 2 Samsung Captivate Glide Camera Replacement: étape 8, image 2 de 2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide Camera Replacement, Camera: étape 9, image 1 de 3 Samsung Captivate Glide Camera Replacement, Camera: étape 9, image 2 de 3 Samsung Captivate Glide Camera Replacement, Camera: étape 9, image 3 de 3
    • Using the opening tool, pry up the camera attachment from the motherboard.
Jessica Martinez
Membre depuis le 09/25/14
260 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-3, Mcgee Fall 2014 Membre de l'équipe USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 624
