Introduction
How to replace the screen on a Samsung Captivate Glide.
Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
Ajouter un commentaire
Remove battery with plastic opening tool or finger.
  • Remove battery with plastic opening tool or finger.
  • Remove the seven screws from backplate using the #00 screwdriver.
  • Remove the back plate using the plastic opening tool.
  • There is a lip on each side, and both must be pried up.
  • You can work your way around the edges after prying the two sides.
  • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  • Disconnect the antenna cable from the motherboard using tweezers.
  • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  • Lift the motherboard out of the base of the phone.
  • Remove the eight screws with the #00 screwdriver.
  • Remove blue tape using the tweezers.
  • Remove screws with the #00 screwdriver.
  • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  • Lift the back plate.
  • To remove to slide flex cable, gently peel back from the back plate and remove back plate.
  • Slide the flex cable through the slot. Be careful to not tear the cable.
  • Set the front plate down.
  • Remove the four corner screws using the #00 screwdriver.
  • Using the plastic opening tool, release all the clips on all four sides holding the screen assembly.
  • You can now remove the back plate by sliding the flex cable through the slot.
  • Use the plastic opening tool to release the main jaw connector, front speaker and camera.
  • By using the plastic opening tool you can release the keypad flex cable from the jaw connecter clamp.
  • Use a heat gun or blow dryer.
  • Heat the outside edges using quick movements for about 45 seconds.
  • Using the plastic opening tool to pry around the edges, release the touch screen from the screen frame.
  • While adhesive is still warm, use the plastic opening tool to gently remove the keyboard flex cable from the screen.
  • You can now replace the screen assembly.
Tyler Moore
Membre depuis le 23/09/2014
136 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 5-3, Mcgee Fall 2014 Membre de l'équipe USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 695
