Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The speaker is easily damaged by playing music too loud. This part is easily replaced.
  1. Remove the back cover by pressing on  the bottom section of the phone and sliding the bottom piece downward.
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Place your finger on the bottom of the battery and lift to remove.
    • Place your finger on the bottom of the battery and lift to remove.
  3. Replace the old battery with the new one.
    • Replace the old battery with the new one.
  4. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Insert the spudger underneath the bottom section of the phone.
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  6. Remove the six 4.5mm #000 Phillips screws.
    • Remove the six 4.5mm #000 Phillips screws.
  7. Starting at a bottom corner, use the spudger to separate the rear case from the front display. Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step. Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  8. Separate the rear case from the phone.
    • Separate the rear case from the phone.
  9. Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
    • Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
  10. Use the plastic opening tool to lift the bottom tab of the plastic ribbon cable connector. Be careful not to use excessive force, you are only releasing the tab that holds the cable in. Pull out the ribbon cable.
    • Use the plastic opening tool to lift the bottom tab of the plastic ribbon cable connector. Be careful not to use excessive force, you are only releasing the tab that holds the cable in.
    • Pull out the ribbon cable.
    • Use a spudger or plastic opening tool to lift up the speaker, and use your hands to remove it.
11 autre(s) ont terminé cette réparation.
Drew Bentz
Membre depuis le 22/09/2011
565 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 20-25, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 membres
9 tutoriels rédigés
It was clear enough to follow, don't know why it got the incorrect text caveat.
I gotta get one of those spudger sets.
Also it did not say where to get the actual replacement speaker.
G Trieste - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 8,556
