Aller au contenu principal
Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: étape 1, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: étape 1, image 2 de 2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: étape 2, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: étape 2, image 2 de 2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: étape 3, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: étape 3, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: étape 3, image 3 de 3
    • Disconnect black and white wire from the I/O board.
    • Remove two 4.6 mm screws from the display hinge using a Phillips #00 screwdriver.
    • Rotate both display hinges upward, away from the components.
  4. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: étape 4, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: étape 4, image 2 de 2
    • Remove the nuts with a 5 mm nut driver socket.
    • Remove all six washers from each side.
  5. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: étape 5, image 1 de 1
    • Remove the hinges from the bar on both sides.
Caden Smith
Membre depuis le 03/28/23
397 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Harley Spring 2023 Membre de l'équipe IUPUI, Team 3-3, Harley Spring 2023
IUPUI-HARLEY-S23S3G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 104
