Aller au contenu principal
Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Bottom Case: étape 1, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Bottom Case: étape 1, image 2 de 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 2, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 2, image 2 de 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 3, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 3, image 2 de 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Battery: étape 4, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Battery: étape 4, image 2 de 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 5, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 5, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 5, image 3 de 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 6, image 1 de 1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Display Screen: étape 7, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Display Screen: étape 7, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Display Screen: étape 7, image 3 de 3
    • Use the spudger to lift the hinge locking the gold colored display cable in place.
    • Slide the cable out to remove it from the motherboard.
  8. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 8, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 8, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 8, image 3 de 3
    • Using the spudger, lift the adhesive securing the wireless card antenna wires.
    • Lift the white and black antenna wires with the spudger.
  9. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 9, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 9, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 9, image 3 de 3
    • Remove the four 4.6mm screws from the display mounts using a Phillips #00 screwdriver.
  10. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 10, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 10, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 10, image 3 de 3
    • Once the hinge screws have been removed, open the laptop.
    • The laptop bottom will separate from the screen once you open it a certain amount.
  11. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 11, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 11, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 11, image 3 de 3
    • Use the iFixit opening tool to pry in between the bezel and screen.
    • You will hear a snapping sound as you work your way around the bezel with the iFixit opening tool.
  12. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 12, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 12, image 2 de 2
  13. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 13, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 13, image 2 de 2
    • Using the spudger, lift the adhesive tape holding the display cable.
  14. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 14, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 14, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 14, image 3 de 3
    • Gently lift the panel up and fold it over to expose the display cable on the backside of the display.
  15. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 15, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 15, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 15, image 3 de 3
    • Use the spudger, lift the hinge locking the gold colored display cable in place.
    • Pull the cable away from you to slide it out of the monitor.
    • Be gentle around the display circuit board. It is labeled "Do not touch."
  16. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: étape 16, image 1 de 1
    • Once the display cable has been removed, lift the screen up and out of the case.
8 autres ont terminé cette réparation.
Mick McCarty
Membre depuis le 03/18/19
980 Réputation
6 tutoriels rédigés
Équipe
4 commentaires
This also works for the XE500C13-K04US
Jonathan - Réponse
It was more challenging than I thought. Reconnecting the antenna wires wasn’t easy. I needed better vision and dexterity to find it easier. Don’t forget to reuse the adhesive tape or you may be disappointed.
Bill Watson - Réponse
Great guide!
Very accurate!
Joshua McVey - Réponse
Just to confirm. You have to tear apart the bottom just to replace the led screen? Can't just remove the bezel?
Xe501c13-k02us
Trisha Kurtz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 23
Total : 1,975
