Aller au contenu principal
Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: étape 1, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: étape 1, image 2 de 2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 2, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
  4. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 4, image 1 de 1
    • Remove the silver bracket.
  5. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Remove the 4.6 mm screw from the I/O board.
  6. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Remove the wire connector from the I/O board.
  7. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 7, image 1 de 1
    • Remove the black and white wires from the I/O board.
  8. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 8, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 8, image 2 de 2
    • Lift the clip of the ribbon cable connector.
    • Remove the ribbon cable from the I/O board.
  9. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: étape 9, image 1 de 1
    • Lift and remove the I/O board from the base of the laptop
Alex
Membre depuis le 03/28/23
178 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-3, Harley Spring 2023 Membre de l'équipe IUPUI, Team 3-3, Harley Spring 2023
IUPUI-HARLEY-S23S3G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 160
